查看: 1482|回复: 2
IEC 62841-4-1:2017 Part 4-1: Particular requirements for chain saws
发表于 2017-10-15 18:22:58 | 显示全部楼层 |阅读模式
IEC 62841-4-1:2017 applies to chain saws for cutting wood and designed for use by one person. This standard DOEs not cover chain saws designed for use in conjunction with a guide-plate and riving knife or in any other way such as with a support or as a stationary or transportable machine.
This standard does not apply to chain saws for tree service as defined in ISO 11681-2; or pole-mounted pruners.
Pole-mounted pruners will be covered by a future part of IEC 62841.
The chain saws covered by this standard are designed only to be operated with the right hand on the rear handle and the left hand on the front handle.
GMT+8, 2026-10-7 00:10 , Processed in 0.021716 second(s), 7 queries , Gzip On, Redis On.
