查看: 891|回复: 0
ISO/IEC TR 22446:2017 Continual performance improvement of IT enabled services
发表于 2017-12-11 19:31:46 | 显示全部楼层 |阅读模式
ISO/IEC TR 22446:2017 Information technology - Continual performance improvement of IT enabled services
ISO/IEC TR 22446:2017 establishes a continual performance improvement (CPI) process that supports service management system (SMS) as defined in the ISO/IEC 20000 series.
This process ensures successful deployment and service performance criteria fulfilment.
This process is based on a predictive performance evaluation method and a related repository.
ISO/IEC TR 22446:2017 is not intended to be used as a means of certification and DOEs not add any requirements to those specified in ISO/IEC 20000-1.
ISO/IEC TR 22446:2017 does not provide specific criteria for identifying the need for risk analysis, nor does it specify the types of risk analysis techniques that are used to support a particular technology.
ISO/IEC TR 22446:2017 does not offer techniques for implementing the continual performance improvement process.
GMT+8, 2026-10-6 22:16 , Processed in 0.016443 second(s), 7 queries , Gzip On, Redis On.
