IEC 62368-3:2017 Audio/video, information and communication technology equipment - Part 3: Safety aspects for DC power transfer through communication cables and ports
IEC 62368-3:2017 applies to equipment intended to supply and receive operating power through communication cables or ports. It covers particular requirements for circuits that are designed to transfer DC power from a power sourcing equipment (PSE) to a powered device (PD).
The power transfer uses voltages at ES1 or ES2 or in very specific cases voltage levels at ES3.
Any cable provided with a connector defined by an industry standard that permits DC power transfer between equipment is considered a communication cable even if communication DOEs not take place. For example, a USB cable can be used just to recharge a portable device battery.
This International Standard is to be used in conjunction with IEC 62368-1:2014.
Keywords: Communication, Safety, Cables, DC Power Transfer
