查看: 1068|回复: 0
IEC 60749-12:2017 Semiconductor devices Part 12: Vibration, variable frequency
发表于 2017-12-16 12:11:07 | 显示全部楼层 |阅读模式
IEC 60749-12:2017 Semiconductor devices - Mechanical and climatic test methods - Part 12: Vibration, variable frequency
IEC 60749-12:2017 describes a test to determine the effect of variable frequency vibration, within the specified frequency range, on internal structural elements. This is a destructive test. It is normally applicable to cavity-type packages
This second edition cancels and replaces the first edition published in 2002. This edition constitutes a technical revision. This edition includes the following significant technical changes with respect to the previous edition:
a) alignment with MIL-STD-883J Method 2007, Vibration, variable frequency.
GMT+8, 2026-10-7 00:24 , Processed in 0.016774 second(s), 9 queries , Gzip On, Redis On.
