查看: 1189|回复: 0
IEC 61869-11:2017 Additional reqireme for low power passive voltage transformers
发表于 2017-12-17 20:21:24 | 显示全部楼层 |阅读模式
IEC 61869-11:2017 Instrument transformers - Part 11: Additional requirements for low power passive voltage transformers
IEC 61869-11:2017 is a product standard and covers only additional requirements for low-power passive voltage transformers (passive LPVT). The product standard for low-power passive voltage transformers is composed of IEC 61869-1, along with IEC 61869-6 and this document with specific requirements.
This document is applicable to newly manufactured low-power passive voltage transformers with analogue output having rated frequencies from 15 Hz to 100 Hz for use with electrical measuring instruments or electrical protective devices.
This document covers low-power passive voltage transformers used for measurement or protection and low-power passive voltage transformers used for both measurement and protection.
GMT+8, 2026-10-6 21:24 , Processed in 0.018521 second(s), 9 queries , Gzip On, Redis On.
