查看: 3270|回复: 0
IEC 60335-2-58:2017 Safety Part 2-58: commercial electric dishwashing machines
发表于 2017-12-18 21:43:48 | 显示全部楼层 |阅读模式
IEC 60335-2-58:2017 Household and similar electrical appliances - Safety - Part 2-58: Particular requirements for commercial electric dishwashing machines
IEC 60335-2-58:2017 deals with the safety of electrically operated dishwashing machines for washing plates, dishes, glassware, cutlery and similar articles, with or without means for water heating or drying, not intended for household use, their rated voltage being not more than 250 V for single-phase appliances connected between one phase and neutral and 480 V for other appliances.
These appliances are used for example in restaurants, canteens, hospitals, and commercial enterprises such as bakeries, butcheries, etc. Examples of such appliances are conveyor dishwashers; batch dishwashers and brush machines. Requirements to avoid backsiphonage of non-potable water into the water mains are specified in Annex BB.
The electrical part of appliances making use of other forms of energy is also within the scope of this standard. As far as is practicable, this standard deals with the common hazards presented by these types of appliances. Attention is drawn to the fact that for appliances intended to be used in vehicles or on board ships or aircraft, additional requirements may be necessary.
This standard DOEs not apply to the following: appliances designed exclusively for industrial purposes, for example machines used in the food industry for cleaning receptacles that serve as packaging for final products (e.g. bottle-cleaning machines), and machines used in manufacturing processes; sterilizers and washer-disinfectors used to treat medical materials (IEC 61010-2-040); dishwashers that do not form one functional unit, for example where a transportation device transfers the load from one separate unit to another;
Key words: Dishwashing Machine, Safety, Commercial
GMT+8, 2026-10-6 21:24 , Processed in 0.015367 second(s), 9 queries , Gzip On, Redis On.
