查看: 2142|回复: 2
IEC 60068-3-5:2018 Confirmation of the performance of temperature chambers
发表于 2018-1-28 11:04:08 | 显示全部楼层 |阅读模式
IEC 60068-3-5:2018 Environmental testing - Part 3-5: Supporting documentation and guidance - Confirmation of the performance of temperature chambers
IEC 60068-3-5:2018 provides a uniform and reproducible method of confirming that temperature test chambers, without specimens, conform to the requirements specified in climatic test procedures of IEC 60068-2 (all parts) and other standards.
This document is intended for users when conducting regular chamber performance monitoring.
This second edition cancels and replaces the first edition published in 2001. This edition constitutes a technical revision.
- Confirmation procedures are clarified.
TC/SC        TC 104 - Environmental conditions, classification and methods of test
ICS        19.040 - Environmental testing
Stability date          2020
GMT+8, 2026-10-6 22:20 , Processed in 0.017758 second(s), 9 queries , Gzip On, Redis On.
