查看: 2587|回复: 3
IEC 60034-27-4:2018 winding insulation of rotating electrical machines
发表于 2018-1-30 21:52:22 | 显示全部楼层 |阅读模式
IEC 60034-27-4:2018 Rotating electrical machines - Part 27-4: Measurement of insulation resistance and polarization index of winding insulation of rotating electrical machines
IEC 60034-27-4:2018 provides recommended test procedures for the measurement of insulation resistance and polarization index of stator and rotor winding insulation of rotating electrical machines. This document recommends minimum acceptable values of insulation resistance and polarization index of winding insulation valid for fully processed low and high voltage AC and DC rotating electrical machines with a rated power of 750 W or higher.
Publication date        2018-01-24
Edition        1.0
Available language(s)        English/French
TC/SC        TC 2 - Rotating machineryrss
ICS        29.160.01 - Rotating machinery in general
Stability date          2023
GMT+8, 2026-10-6 23:03 , Processed in 0.019477 second(s), 8 queries , Gzip On, Redis On.
