查看: 475|回复: 0
IEC 62056-5-3:2017 Part 5-3: DLMS/COSEM application layer
发表于 2017-8-17 10:18:31 | 显示全部楼层 |阅读模式
IEC 62056-5-3:2017 Electrcity metering data exchange - The DLMS/COSEM suite - Part 5-3: DLMS/COSEM application layer
IEC 62056-5-3:2017(E) specifies the DLMS/COSEM application layer in terms of structure, services and protocols for DLMS/COSEM clients and servers, and defines rules to specify the DLMS/COSEM communication profiles. It defines services for establishing and releasing application associations, and data communication services for accessing the methods and attributes of COSEM interface objects, defined in IEC 62056-6-2 using either logical name (LN) or short name (SN) referencing. This third edition cancels and replaces the second edition of IEC 62056-5-3, published in 2016. It constitutes a technical revision. The significant technical changes with respect to the previous edition are listed in Annex K (Informative).
Publication type        International Standard
Publication date        2017-08-10
Edition        3.0
TC/SC        TC 13 - Electrical energy measurement and controlrss
ICS        17.220 - Electricity. Magnetism. Electrical and magnetic measurements
35.110 - Networking
91.140.50 - Electricity supply systems
Stability date          2022
Pages        348
File size        15726 KB
GMT+8, 2024-5-3 19:06 , Processed in 0.020545 second(s), 6 queries , Gzip On, Redis On.
