查看: 771|回复: 0
CISPR 32:2015 ed2.0 EMC of multimedia equipment - Emission requirements
发表于 2017-8-17 10:26:25 | 显示全部楼层 |阅读模式
CISPR 32:2015 ed2.0 Electromagnetic compatibility of multimedia equipment - Emission requirements
Publication date        2015-03-31
CISPR 32:2015 is available as Standards+ CISPR 32:2015 which contains the International Standard and its Redline version, showing all changes of the technical content compared to the previous edition.
CISPR 32:2015 applies to multimedia equipment (MME) as defined in 3.1.24 and having a rated r.m.s. AC or DC supply voltage not exceeding 600 V. This publication covers two classes of MME (Class A and Class B). The MME classes are specified in Clause 4. The objectives of this publication are:
1) to establish requirements which provide an adequate level of protection of the radio spectrum, allowing radio services to operate as intended in the frequency range 9 kHz to 400 GHz;
2) to specify procedures to ensure the reproducibility of measurement and the repeatability of results.
This second edition cancels and replaces the first edition published in 2012. This edition constitutes a technical revision.
Technical Committee        CIS/I - Electromagnetic compatibility of information technology equipment, multimedia equipment and receivers
ICS Codes        33.100.10        Emission
Stability date        2018
GMT+8, 2024-4-28 10:00 , Processed in 0.031967 second(s), 7 queries , Gzip On, Redis On.
