查看: 750|回复: 0
IEC 61196-1-113:2018 Electrical test methods - Test for attenuation constant
发表于 2018-1-18 20:49:01 | 显示全部楼层 |阅读模式
IEC 61196-1-113:2018 Coaxial communication cables - Part 1-113: Electrical test methods - Test for attenuation constant
IEC 61196-1-113:2018(E) applies to coaxial communications cables. It specifies a test method for determining the attenuation constant of coaxial cables for use in communications systems. The test is applicable preferably at frequencies ≥ 5 MHz, but also for lower frequencies if the magnitude of the complex characteristic impedance is approximately equal to the nominal characteristic impedance of the specimen or if a form fitting function is applied.
This second edition cancels and replaces the first edition published in 2009. This edition constitutes a technical revision.
This edition includes the following significant technical changes with respect to the previous edition: diverse form fitting equations are provided.
Publication date        2018-01-12
Edition        2.0
TC/SC        TC 46/SC 46A - Coaxial cablesrss
ICS        33.120.10 - Coaxial cables. Waveguides
Stability date          2022
GMT+8, 2024-4-29 19:27 , Processed in 0.019837 second(s), 5 queries , Gzip On, Redis On.
