查看: 498|回复: 0
IEC PAS 61076-3-126:2018 5 pole power connector for industrial environments with
发表于 2018-1-19 18:05:33 | 显示全部楼层 |阅读模式
IEC PAS 61076-3-126:2018 Connectors for electrical and electronic equipment - Product requirements - Part 3-126: Rectangular connectors - Detail specification for 5 pole power connector for industrial environments with push-pull locking
IEC/PAS 61076-3-126:2018(E) covers rectangular IP65/IP67 connectors with 5 poles for electric power supply up to 16 A. These connectors consist of fixed and free connectors, either rewirable or non- rewirable (for both portions). It uses the general function principles of the push-pull connector housing system described in IEC 61076-3-117 with IP65/IP67 degree of protection according to IEC 60529 for harsh applications.
Male connectors have 5 square 1 mm electric contacts, with 16 A rated current. Connectors according this document are without breaking capacity COC according to IEC 61984, therefore they are not intended to be engaged or disengaged in normal use when live or under load, if not otherwise specified by the manufacturer.
Key words: Connector, Rectangular Connector, 5 Pole, Push-pull locking
Publication type        Publicly Available Specification
Publication date        2018-01-09
Edition        1.0
TC/SC        TC 48/SC 48B - Electrical connectorsrss
ICS        31.220.10 - Plug-and-socket devices. Connectors
Stability date          2020
GMT+8, 2024-5-5 07:06 , Processed in 0.026736 second(s), 5 queries , Gzip On, Redis On.
