查看: 785|回复: 0
IEC 61643-352:2018 telecommunications and signalling network surge isolation ...
发表于 2018-1-19 18:07:20 | 显示全部楼层 |阅读模式
IEC 61643-352:2018 Components for low-voltage surge protection - Part 352: Selection and application principles for telecommunications and signalling network surge ISOlation transformers (SITs)
IEC 61643-352:2018 covers the application of surge isolation transformers (SITs) that are used in telecommunication transformer applications with signal levels up to 400 V peak to peak. These transformers have a high rated impulse voltage with or without screen between the input and output windings. SITs are components for surge protection and are used to mitigate the onward propagation of common-mode voltage surges. This document describes SITs' selection, application principles and related information. This document DOEs not cover power line communication transformers.
Keywords: surge isolation transformers (SITs), telecommunication transformer applications
Publication date        2018-01-10
Edition        1.0
Available language(s)        English/French
TC/SC        TC 37/SC 37B - Components for low-voltage surge protectionrss
ICS        33.040.99 - Other equipment for telecommunication systems
Stability date          2021
GMT+8, 2024-5-5 02:35 , Processed in 0.019682 second(s), 5 queries , Gzip On, Redis On.
